21 - 24 of 24 Posts
ANOTHER HAPPY CUSTOMER!
I searched for the problem, and found the answer in this thread that started 7.5 years ago - easy fix.
THANKS!
We are now printing the clip that mounts to the flap hinge point where the alignment pin and spring mount. Chickenwire built the file and is printing them in metal. I have printed them in nylon. We are trying to convince CW to build a model for the flaps so I can print them in ABS as replacement parts. Currently new flaps are close to $200 from online sources.
Installation Tip
This post was very helpful for me...found similar assortment of "door lock rod clips" at Advance Auto (75450). There were two in the pack that worked for me (both sides were in need of replacement). One tip: I couldn't get the clip to fit in the holder hole with the cable already inserted into the clip. I put the clip in the hole first and then found that the cable was able to go in after that.
21 - 24 of 24 Posts
