Has anyone had their battery on Sky replaced at a GM Dealer? Just was wondering what the charge would be for a decent battery? Would they kno to use the hockey Pucs? Jim
Advance won’t touch it. They don’t do anything other than a simple cable swap, and you might not get that. You can change it out-not that big a deal.Don't pay for a dealer replacement. Heck AdvanceAuto says they will replace for free, but IDK since the fender has to come off, maybe not free. But still it's only 2- 10mm bolts and maybe 8- 7mm little bolts to take the side panel off. You do not have to take off the inner frame. You should be able to get the battery out but it's a little tricky with a full size battery to get the top posts past it. Get an AGM battery not a water based battery, no worries of spillage, but they are a little more costly. I think Optima's are around $230.
To answer your question on how much is labor for GM to replace your battery....figure 200 dollars and that does not include the cost of the battery. Bill is correct....no lift needed.Never had a battery replaced at a GM dealer, did it myself. Not sure why there would be a need to lift the car or use hockey pucks, because there isn’t a need to lift the car to replace the battery. 🤔
That is the method referenced by @SaturnSkyDude in the post previous to yours. That method requires removal of the wheel, and therefore lifting of the car, or at least one corner.IIRC there was a youtube video showing an alternate way to replace the battery via the wheel fender liner therefore negating the need to remove the fender panel. Aligning it back can be a pain.
The need to lift the car is based on the second method of battery exchange that requires removal of a wheel but avoids removal of the fender. It seems to be more popular with Solstice owners because of the reported greater difficulty of aligning the Solstice fender compared to the Sky.I just did my 2008 in my garage. No need to lift the car at all. If you want to get it a bit higher for easer access just drive up on some ramps. The fender is super easy to remove and you don't have to remove the metal brace to get the battery out and back in. Took me about 20 minutes. Search YouTube for a tutorial.
Use one of these and you don’t have to lose the radio presets.I have replaced several batteries and the only thing I have lost is radio presets.
True, but I never thought it was that big a deal, and now my new radio retains them by itself.Use one of these and you don’t have to lose the radio presets.
John,True, but I never thought it was that big a deal, and now my new radio retains them by itself.
The Atoto A6.John,
Which radio/brand did you go with?
Bill
