Where do live ?? It should only take a few days to make it out of QC if it it's a base Sky. And the shipping time depends where you live.Need some help. Current Event 3800 Produced, Ship-to 121975 BFC:1and
the last 5 numbers of my VIN 110483 What does this mean and abou how long till I get my SKY Any help will be a BIG HELP.
THANK YOU ED Redbones
Over 10,000 already?the last 5 numbers of my VIN 110483
If you see some of my earlier post regarding how the build year runs. They aren't almost there.They are also sharing the same vin sequence with the Solstice.apparently so! If the limit is 12k, they are almost there!
Does that mean beginning with the 2007 SOL model year Sky and Sol are running the same VIN number block?If you see some of my earlier post regarding how the build year runs. They aren't almost there.They are also sharing the same vinm sequence with the Solstice.
Yes. And the Opel and Daewoo when they start production.One big Kappa family of vins.Thats what I've been told.Does that mean beginning with the 2007 SOL model year Sky and Sol are running the same VIN number block?
2007 model production until end of August
Sky 6484 (build since Januar 06)
Sol 4085 (build since last week of June 06)
total 10579 >>> should be the last VIN in August 2006![]()
Thank's for info. Just asked that question on the Aug. production thread.Yes. And the Opel and Daewoo when they start production.One big Kappa family of vins.Thats what I've been told.
So you are saying that my SKY, for example, with VIN 2040 is not the 2040th SKY built, but the 2040th Kappa built in the 2007 run. That would make it, more than likely, one of the first 1000 SKYs produced.If you see some of my earlier post regarding how the build year runs. They aren't almost there.They are also sharing the same vin sequence with the Solstice.
Your Sky with VIN 2040 is the 2040 build Sky.So you are saying that my SKY, for example, with VIN 2040 is not the 2040th SKY built, but the 2040th Kappa built in the 2007 run. That would make it, more than likely, one of the first 1000 SKYs produced.
OK. Got it now.In the beginning from feb untill June 24th the vins were Sky vin numbers only. Then when they started the 2007 Solstice on June 26th thats when they start mixing vins. probably had something to do with the fact the Solstice was a 2006 model.So your vin would be the 2040 Sky built because it was before the 2007 Solstice. I think the mixed vin numbers start around 4500.
