101 - 120 of 164 Posts
Discussion Starter · #101 ·
Good to see it coming back together with all of the new bits. I've been waiting to see your final outcome with the new hood. Bummer about the turbo and the radiator coolant pipe. Hopefully those get sorted out soon. Do you think you're going to have everything back together before NASSAM?
I'm trying to wrap my head around the wrench break. Having just did the timing chain myself I can't imagine the wrench breaking with that force. IIRC it's like 75lbs plus 120 degrees or something like that?
Hadn’t realized you had a powder coated valve cover. Very nice.
I also have one of those RPM upper rad hoses sitting in a box, and hadn’t realized the rubber coupler made it look that way. Not sure how I feel about it now.
And a suggestion re: your missing metal piece- the subframe just behind the rack has these 2 large openings. Maybe it slid in there...
I have bent wrenches, but never broken one. What brand is it, and what broke off?
I'm headed out the door gents, so I'll provide a picture later. My honest to goodness hope is it disappeared in Sky Narnia, and not the front timing area.
I'll deal with a rattle. My heart will break if the engine breaks. I'm going to have ZZP start with an easy e85 tune. My goal is to have all kinks ironed out before NASSAM.
I highly doubt it will be fully painted/ wrapped by NASSAM though. I just want it to run well at this point and have no oil leaks. I was absolutely following proper torqueing.
It broke while I was doing the 120 degrees bit.
Discussion Starter · #103 · (Edited)
My coolant pipe doesn't fit right. I'm working on getting a proper fit for it.
Automotive tire Motor vehicle Automotive design Automotive lighting Aircraft engine
When I went to fill the radiator with coolant, it spilled all over the floor, because the $700 radiator doesn't fucking come with a drain plug.
I tried the OEM plug, and it isn't the same thread. So cool.
Vehicle Automotive tire Car Automotive exterior Hood
To get the fuel pump installed, I had to go back and forth with the mechanic, who was legitimately nice and helpful, but I was wasting his time as a customer, when the proper install procedure could have just been properly documented. Apparently I'm the first person on the planet to post what a fully installed RPM HPFP looks like:
Automotive fuel system Motor vehicle Hood Automotive design Automotive tire
Martin has been incredibly polite. His mechanics truly care about the platform. I'm just astonished at how many "mix-ups" have occurred.
Hi I might be interested in buying that hood, do you have the contact information of the person who's selling the hood?
If you’re looking for the returned damaged hood, it was sitting outback of RK Sport in Round Rock, TX the last I saw it. What they did with it I have no idea. I’m not sure if they destroyed it or sold it. That was back in February. Cesar was who I talked with while I was there.
Discussion Starter · #107 ·
Martin at RPM to the rescue!
He's going to send me the 90 degree elbow for the coolant return pipe, the hardware to install the intercooler, and radiator drain plug.
Martin was super help, polite, and solution oriented. I appreciate it.
I plan on buying those guys a coffee when I visit at the end of the month.
Discussion Starter · #108 ·
The list is getting mighty small. For now I'm still waiting on the parts from RPM. I still need the drain plug, proper coolant elbow, and mounting hardware for the intercooler... I was told it would arrive by Wednesday or Thursday... It is now Sunday... I had a "first start up" party planned with my neighbors... It just turned into a regular party, because RPM can't be trusted.
Sleeve Motor vehicle Automotive exhaust Automotive design Automotive exterior
Car Vehicle Tire Automotive tire Hood
So... While uploading the e85 tune, my battery died...
Computer Personal computer Computer keyboard Speedometer Peripheral
Had to spend $200 to find out if I killed the ECM...
Rectangle Font Bumper Automotive parking light Gas
Turns out I didn't kill the ECM or TCM. Everything uploaded just fine.
Now to wait for the RPM parts while it snows outside
Sky Snow Plant Branch Natural landscape
Sorry to inform you, but per zzp you need to remove the hpfp gasket.
Discussion Starter · #115 ·
Here's the first drive today!!!
Compared it my 2022 GR86, the Sky is a freaking ROCKET.
It was a drive and check day.
I got lots of good information on what I needs to beef up next. I have a LOT of oil vapor going from the valve cover to the cold air intake. I bought a second catch can to separate the two. I completely got rid of the RPM Motorsports catch can. Everything they make is absolute garbage.
I'm so done with them.
Discussion Starter · #116 ·
I forgot to mention! I found the broken piece of wrench!!!! It was hidden on the roof under the hoods.
Guitar accessory Hood Wood Foot Automotive exterior
Here's a few pictures from yesterday:
Tire Wheel Vehicle Car Vehicle registration plate
Car Wheel Sky Cloud Tire
Tire Cloud Wheel Car Sky
Finally, one of the main reasons I embarked on this journey, was due to several oil leaks. One specifically I feared was a rear main seal leak. So far no oil is coming out. The biggest thing I did to fix this was change the o-rings in the oil cooler.
Discussion Starter · #117 · (Edited)
The RK Sport hood has been installed. It took 4 M8 x 1.25 bolts at 25mm length. They weren't easy to align...
Wheel Tire Motor vehicle Hood Automotive tire
It doesn't fit great, and the metal posts near the windshield push it a good 2" above where the hood is supposed to land. I hope to have it sorted before NASSAM.
Started installing the catch cans in their proper place. All told, the catch can system will have cost around $150-200 to have both loops set up.
Automotive tire Hood Motor vehicle Automotive design Automotive lighting
I HIGHLY recommend doing your own system over buying a single premade one. One of the gents on the Solstice forum said my open filter cans might cause lean conditions, so maybe don't do exactly as I do.
Discussion Starter · #120 ·
Did a data log yesterday! It felt great, but there was some KR at wide open throttle. Sent off the log to the tuner last night. Jason Aho shared se great insight into it. Can't wait to buy that guy a drink.
Blue Font Screenshot Rectangle Line
I'm wet sanding my car before I start wrapping it. The RK Sport hood definitely needed some sanding.
Tire Wheel Vehicle Hood Automotive tire
