I hope that you found the problem.I just wanted to check in and provide a quick update. If you've read all my posts here, you know I changed the ignition switch about 2 weeks ago and immediately had a "no crank" which required me to disconnect/reconnect the battery. Therefore, I assumed the issue was not resolved. However, ever since that time, the issue has not happened again. It has been cranking and starting every time i ask it to. I've driven it on multiple small drives and have started it at least once a day since that time and let it run for a few minutes. I'm cautiously optimistic that the ignition switch was the cause of my problems, but if I have an issue again, I will update this thread. I want to thank everyone who took the time to read my post and offer me suggestions, it was and is truly appreciated.
