Sky won't start
290 Views 6 Replies 4 Participants Last post by  jzjfamilyman
My 2007 sky won't start. I have power when I turn key on, but when I try to start it nothing. New starter and I don't think it's security. The lock image goes off after the key is on for couple seconds. Appreciate any help.
1 - 7 of 7 Posts
Welcome to the forum.
Manual or automatic?
i believe you can use the 10-10-10 method on these cars.
get in the car turn off everything, shut the door. insert key, turn to "on" do not go all the way to start. leave for ten minutes, security light will go out on dash, turn off car ten turn back to on and repeat 2 more times. after third time turn off. then try to start the car, it should pe programmed.
If as he says the lock image goes off after a few seconds I doubt a 30 min relearn will work as the lock has to say on for the full 10 minutes each time.
I hook up a snap on scanner and it says there is no key in the ignition. The key was on and turned to on position.
1 - 7 of 7 Posts
