Alot of people are curious about this difference. Originally the Solstice was going to be 170hp as well, but as it got nearer to production, it changed to 177hp. I believe that since both cars are using the same engine, that the Sky will follow and will be 177hp as well. It only makes sense to tell the cunsumers a hp number thats lower than what's really released, it gets the exitement going again once we find more hp and goodies. :cheers: Not that i really need more excitement. I was already going to :brentil: Spontaneously combust when i saw the SKY. The car is so HottPaulWall said:Sky's engine is rated at 170hp & Sol is 177hp. Why the 7hp difference?![]()
Wow,.. A/C as an option?? :lol: When A/C is not standard on a car, and you have to pay to have it, thats inhumane. :banghead: lol. I was spoiled when i got my Ion Quad Coupe, I forgot other cars dont come with that. Thats why I got to get me da SKY,.. essentials like that have always come standard on Saturns. Plus fee Carwashes, uh, for free :willy:sky_vue said:Sol has the AC as an option![]()
Don't yoo mean "Hyposynthesis" hahasky_vue said:I'm still not completely sure that the Sky will increase in the HP just to come to par with the Sol. AC being an option might account for that as is the case between the Vue w/ the honda engine and the honda pilot. Same engine.. except that the Vue has electronic steering vs. hydrolic. This differnce gives it an extra 10 horses @ test. Since the AC is an option then they can rate a sol w/out the ac system in place.. giving it a slight edge.
But anyone who has a better explanation is welcome.. cause it's just a hypothesis
Adding A/C might affect Torque, which in turn would affect HP. Engine's really don't produce HP per say, they have a specific Torque rating at a specific RPM, these numbers stuffed into en equation give you HP at that RPM. I think the equation is HP = (RPM x Torque)/5252. The reason the A/C would affect Torque is the same reason a Supercharger affects Torque; it adds a pully to the Serpintine Belt, causing some of the Engine Torque to be lost running the pullys via the belt, and thus not transfered to the Transmission and the Drive Wheels.sky_vue said:I'm still not completely sure that the Sky will increase in the HP just to come to par with the Sol. AC being an option might account for that as is the case between the Vue w/ the honda engine and the honda pilot. Same engine.. except that the Vue has electronic steering vs. hydrolic. This differnce gives it an extra 10 horses @ test. Since the AC is an option then they can rate a sol w/out the ac system in place.. giving it a slight edge.
DuSpinnst said:Adding A/C might affect Torque, which in turn would affect HP. Engine's really don't produce HP per say, they have a specific Torque rating at a specific RPM, these numbers stuffed into en equation give you HP at that RPM. I think the equation is HP = (RPM x Torque)/5252. The reason the A/C would affect Torque is the same reason a Supercharger affects Torque; it adds a pully to the Serpintine Belt, causing some of the Engine Torque to be lost running the pullys via the belt, and thus not transfered to the Transmission and the Drive Wheels.
i wonder if it really is that simple. that would make for a really good reason. someone will have to check with GM once these cars are out and their guards go down a little.DuSpinnst said:Adding A/C might affect Torque, which in turn would affect HP. Engine's really don't produce HP per say, they have a specific Torque rating at a specific RPM, these numbers stuffed into en equation give you HP at that RPM. I think the equation is HP = (RPM x Torque)/5252. The reason the A/C would affect Torque is the same reason a Supercharger affects Torque; it adds a pully to the Serpintine Belt, causing some of the Engine Torque to be lost running the pullys via the belt, and thus not transfered to the Transmission and the Drive Wheels.
So you are saying it's a camshaft swap? The Solstice uses more agressive cams? Or is this ECU/PCM related?brentil said:If you go read some of the posts in the technical area where this belong, we've gone over it a couple times.
The Solstice was listed as 170 HP before its specs were officialy announced, at that time the 177 HP became official. The Sky has had its official specs announced as 170 HP, don't expect that to change.
The Solstice gets 177HP @ 6600 RPM with 20/28 MPG (Manual)
The Sky gets 170HP @ 6400 RPM with ??/?? MPG
The Cobalt SS gets 171HP @ 6200 with 24/32 MPG (Automatic)
The G6 Gets 167HP @ 6300 RPM with 23/34 MPG (Automatic)
The Solstice's HP value is rated with the AC, as is it's rated weight value too. The reason they're different is due to tuning. Pontiac is the performance brand, therefore the Solstice's 2.4L VVT is getting tuned in a way to produce more power, but at the expense of Fuel Economy. You can see above the engine is designed to rev slightly higher then the Sky's varient. As seen recently the G6 & Cobalt SS's Fuel Economy values have been released and they get in the 24/33 MPG range on the same engine but in the ~170HP range. The Solstice gets a much lower 20/28 MPG [due to tuning, CD, and gearing]. Look at the Fuel Economy for the other two cars. The values are off that much due to tuning, CD, and gearing. With the way the Sky will be tuned expect it to get better Fuel Economy then the Solstice but worse then the Cobalt/G6 due to it's much higher CD and sportier gearing.
More then likely ECU tuning. A/F ratios, redline, etc.DuSpinnst said:So you are saying it's a camshaft swap? The Solstice uses more agressive cams? Or is this ECU/PCM related?
Hence only a 7 HP gain as opposed to anything meaningful. The bad part about that is unless you actual upgrade the mechanical components you are more likely to damage something due to improper timing. Although I am sure GM way underrates thing to begin with.brentil said:More then likely ECU tuning. A/F ratios, redline, etc.
It's the cheapest way for GM to make one engine across 5 cars yet give each one it's own personality.
If it really is all ECU based like I think it is, I would love to have a ECU programmed with various modes on it kinda like the Turbo Toys option on the Neon SRT-4 that you can choose by turning a knob. A higher economy lower power mode, base mode, and 100 octane race mode.DuSpinnst said:Hence only a 7 HP gain as opposed to anything meaningful. The bad part about that is unless you actual upgrade the mechanical components you are more likely to damage something due to improper timing. Although I am sure GM way underrates thing to begin with.
here is the definition of SAE net HorsepowerPaulWall said:Sky's engine is rated at 170hp & Sol is 177hp. Why the 7hp difference?![]()
Turbo Toys would be nice so would Stage Kits. I know someone who has a Stage 3 SRT-4, and it is FAST. Mind you it still looks ridiculous (Neon's are bubbles!)brentil said:If it really is all ECU based like I think it is, I would love to have a ECU programmed with various modes on it kinda like the Turbo Toys option on the Neon SRT-4 that you can choose by turning a knob. A higher economy lower power mode, base mode, and 100 octane race mode.
