I I cannot seem to get my slave hose, the end that goes into where the clutch pedal is it just will not go in see picture please
I removed it so that I could remove the transmission so I could change my clutch that's all I did putting it back in trying to and it is just absolutely will not enter that fitting.There isn't much that can keep it from going in if the retaining clip is out.
Can you give any background? Why did you remove it and what have you done since then?
If you zoom in on that picture you'll notice there is no clip at all and I have inserted as far as I can with as much pressure as I possibly can exert I even used a pry barI I cannot seem to get my slave hose, the end that goes into where the clutch pedal is it just will not go in see picture please
As @Hoosier GXP stated, the alignment can be delicate, but there is no way that a pry bar should be necessary, or used. I would make sure that nothing is in the hole, and that the end of the tube is round and not damaged.If you zoom in on that picture you'll notice there is no clip at all and I have inserted as far as I can with as much pressure as I possibly can exert I even used a pry bar
I haven't done this on a Sky but others typically use an o-ring. Remove the o-ring if there is one and place it in the proper slot before inserting.I I cannot seem to get my slave hose, the end that goes into where the clutch pedal is it just will not go in see picture please
Good eye. On second (or maybe third) look it does appear that the o-ring is out of its groove.I haven't done this on a Sky but others typically use an o-ring. Remove the o-ring if there is one and place it in the proper slot before inserting.
Yes I can I'm not home at the moment but I will when I get home that really makes perfect sense that HD alignment because right taking that thing off of there was so simple it just once I pulled the clap it just came right out call EasyGood eye. On second (or maybe third) look it does appear that the o-ring is out of its groove.
@rrwebster3 : Can you post a picture of the hose end?
The clutch does not have a bleed screw, they call it a self-bleedng system. Basically you completely depress the pedal, hold it for 5 seconds, release it slowly, wait 5 seconds, then repeat until you have a firm pedal. Make sure that the fluid stays above the divider in the reservoir.Yes I can I'm not home at the moment but I will when I get home that really makes perfect sense that HD alignment because right taking that thing off of there was so simple it just once I pulled the clap it just came right out call Easy
I was reading the procedure regarding living and they talked about a bleed screw I have been all over this thing I don't see a bleed screw anywhere where is the bleed screw?
That is the best thing I've read regarding this whole clutch replacement procedure yet thank you for that informationThe clutch does not have a bleed screw, they call it a self-bleedng system. Basically you completely depress the pedal, hold it for 5 seconds, release it slowly, wait 5 seconds, then repeat until you have a firm pedal. Make sure that the fluid stays above the divider in the reservoir.
Is the proper slot the one I have circled with the smaller Circle?I haven't done this on a Sky but others typically use an o-ring. Remove the o-ring if there is one and place it in the proper slot before inserting.
Very possibly. Unless the o-ring is in another groove. Hence the desire to see the end of the hose.Is the proper slot the one I have circled with the smaller Circle?
Here is what the inside of the portion that comes from the master cylinder looks like using one of those fancy TV thingies
The o-ring placement in the hose end looks correct, and I assume that the fitting itself is still round. I don't see anything wrong with the master cylinder recess, but I can't really see anything, so that doesn't mean much.Here is what the inside of the portion that comes from the master cylinder looks like using one of those fancy TV thingies
] no this is a memory issue 2 a.m. two nights ago as I was wrapping up for the night I put a plug in that hole so it wouldn't leak I am so sorry to waste everybody's time what it was cuz I was trying to put it in with the plug still in there I pulled it out and it went right in.The o-ring placement in the hose end looks correct, and I assume that the fitting itself is still round. I don't see anything wrong with the master cylinder recess, but I can't really see anything, so that doesn't mean much.
This may just be an alignment issue.
