Worked great on Saturn Sky but also seems to work on Pontiac Solstice, takes about 5 minutes to swap. I had water in passenger side, and found a small crack in the original so decided to give these a go after seeing them on Facebook.
Squeezed top clip gently and pried carefully out of bumper. Pull original bulb socket with original marker then twist unlocked it to pop out the bulb.
Was not sure if the smoked LED replacement "bulb" is polarized but the connector had red and black wires on the new bulb blade connector.
Checked which blade receptacle the original socket was positive 12v or ground on drivers and passenger side with the bulb removed and made sure the corresponding red wire on the new unit was connected to positive. See pictures.
Aligned socket and pushed it in and locked with twist. Take note that there are 2 small tabs and 2 larger ones, it only fits one way. After testing light functions, slide bottom alignment tab in, and pushed in the clip, repeated for other side. Made sure bulbs are still locked in.
Easy install! Hope they last.
Amazon.com: Miniclue 2pcs Smoked Lens Amber LED Lights Front Side Marker Lamps Compatible with 2006-2010 Pontiac Solstice,2007-2010 Saturn Sky: Automotive
Buy Miniclue 2pcs Smoked Lens Amber LED Lights Front Side Marker Lamps Compatible with 2006-2010 Pontiac Solstice, 2007-2010 Saturn Sky: Side Marker Assemblies - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
