Question: Where is the best place to order one from. Dont really like the stock one, toooooo tall :willy: Thanks for any imput....:thumbs:
When you go to the www.carccessory.com web site you will see a note on each antenna indicating reception performance. Such as for the A-Series antenna, it says Reception: 3 out of 5moni6 said:Noticed our reception decreased dramatically with our stubby. We live closer to the mountains so maybe that had a lot to do with it. The look of it is way better than the original one.
Which one did you exactly buy?Luke Sky Watcher said:Got mine here. http://www.carccessory.com/product.asp?key=Stubby_Short_Antenna_
:thumbs:
Works fine for me and took about 30 seconds to change. Have photo if you need one. Just PM me.
:cheers:
Hey thanks. We got the O-series thinking it would be good enough but it's not. I am going to buy another one with a 4/5 rating and see the difference. They are only $8 so no big deal.dmbdlatc said:When you go to the www.carccessory.com web site you will see a note on each antenna indicating reception performance. Such as for the A-Series antenna, it says Reception: 3 out of 5
Others in the stubby series say Reception: 4 out of 5
You might want to keep that in mind when ordering an antenna if you are going to drive in marginal areas. The antenna is easy to change and the OEM does not take up much room in the trunk. It could be taken along for the ride on a long road trip if reception gets bad.
The antenna will fit in the Trunk!!!??? :lol:dmbdlatc said:The antenna is easy to change and the OEM does not take up much room in the trunk. It could be taken along for the ride on a long road trip if reception gets bad.
I have the exact same radio, but still want to listen to local radio once in a while...nighttamer said:Who needs an antenna? I got XM and 6 cd player. I took the antenna off and put a rubber cap over the stud. I had a wire belt rack, from Home Depot, that I cut the end of the rubber protector off of.![]()
Hey Luke. Sales Guy called me after you advised him which antenna you bought. It look's great but up here in Spring Hill the reception is horible for all the Tampa station's. But what the hell, I mostly play MP3'sLuke Sky Watcher said:Got mine here. http://www.carccessory.com/product.asp?key=Stubby_Short_Antenna_
:thumbs:
:cheers:
Dont know what to sayBarry said:Hey Luke. Sales Guy called me after you advised him which antenna you bought. It look's great but up here in Spring Hill the reception is horible for all the Tampa station's. But what the hell, I mostly play MP3's
