41 - 49 of 49 Posts
Say someone did want to add a water/meth system... what are the best options out there right now? Most of the threads on it are 10 years old, and I have to think that controllers have come a long way since then. The idea that a fail safe if you run out of fluid really peaked my interest.
I watch the Race Proven Motorsports YouTube channel for fun, but they install a lot of meth systems and have their own pieced together system available for $1,000 (https://race-proven-motorsports.myshopify.com/products/rpm-meth-system-parts-only) but I doubt the tank that they use would fit anywhere in the car. Anyone have any feelings on the parts that they use, as you can buy a "fender mount" version of the ProMeth kit that would probably fit in the trunk easily. Or maybe this should be it's own thread...
Could be but at the same time since we've opened this thread to alternatives to bigger turbos it may not be that far off topic. I don't think this should become a discussion as to the nuances between different meth systems but if someone wants to post suggestions or for tank options I don't think that's too far out there.
I've heard many (Not necessarily Sky owners) use their washer fluid tanks as a meth kit since you can run 20% washer fluid and water as a solution. Kind of make it do double duty.
Vendor
Almost every install we have done on the Solstice/Sky with Water/Meth has used the windshield washer reservoir for the tank. We keep the windshield washer pump hooked up and the reservoir does double duty, that is why we also typically tune the Water/Meth using the -20 windshield washer fluid as you can use it to keep your windshield clean and your engine making more power.
Not to mention using the washer fluid resivoir gives you the notification when it's low.
Really does make the most sense.
How much liquid does it hold though and how long would it last with normal use. I'd hate to be refilling it more often than I was putting gas in the car
Vendor
The reservoir holds about a gallon. You do not have to spray that much to get a very good benefit, we typically use the small nozzle that comes with the AEM kit for installations. If you are using the small nozzle and have the on pressure set around 7-8 psi with full duty cycle by 23psi, the gallon reservoir will usually last a couple tank fulls. This is very dependent on driving style though and how much full throttle you do.
Curious what the difference is between the Performance Autowerks big wheel turbo and the RPM Motorsports big wheel turbo.
Can anyone speak to this? Are all "Big Wheel" turbos created equally? Can any owners recommend a specific brand?
You are limited by how much room there is in the housing for a larger wheel. I had figures on the diameter of the one I have (somewhere) but would have to find them and then you'd have to ask RPM what diameter they are going to.
41 - 49 of 49 Posts
