I had a car I was working on a while back and I had the common problem of the turn signal not canceling once I made a turn. I swapped in a new stock only to find it did the same. Once more I switched out the stock with a different one and it to failed to work. After some thought I decide to see if the clock spring tape was broken but to my surprise it was intact. I then removed the clock spring to find that the ring on the back had become unattached from the housing. There were no broken tabs so I snapped the ring back in and turn signal cancel problem was fixed. I thought I would share this info to help out the next one that encounters the same problem.
