I discovered what the so-called heat problem was when removing the Sky hood vents:
The problem isn't from removing or replacing the hood vents with functional hood vents. It is from removing or modifying your hood insulator. This is a very important and crucial part to keeping your temps down under the hood of the Sky.
You should not elliminate the hood insulator or cut holes allowing any hood surface areas to receive direct radiant heat. The metal hood will retain the heat and it will cause heat to buildup under the hood.
I made some aluminum channels out of 10" flashing and shaped it to spring load under the hood in 4" x 21" rectangular holes cut in to the hood insulator carpet.
Here's what they look like installed:
Using the hood insulator carpet and adding the channels to block the radiant heat yet still allow air to disipate brought the under hood temp down by 70 degrees.
I'm now waiting for my Saturn Motor Sports functional hood vents to arrive to complete my installation.
