I just had the Vertical Doors Inc. kit installed today on the RL and have bumped into some problems. I would really appreciate any info that any forum members here could offer who have the kit. For starters, it was installed by a group that does a lot of these and this was not the first Sky.
There are some alignment issues with the front fender panels, hood, and doors that were not here before. Also, when you open the door, it swings out and up a little, then hangs up and pushes out a little farther before going up. It is very difficult to close sitting inside and you have to put a little pressure (either up or down depending) on the door to swing it shut as if it is not lining up quite right with the door latch in the frame. Is this normal?
