Does anyone have any input on stockpiling parts? I notice more and more parts are being discontinued. I have started collecting items I feel may be needed down the road, but was curious what others thought.
I ordered theseNo. That weatherstrip is attached to the top of the windshield frame.
Good point. I'm sure these parts are old and have been sitting in the michigan warehouse for years. I'll see how they look and decide if I want to use them or not. The ones on I have are almost flat so there's no restoring them.Rubber parts are always an issue unless they are still manufacturing replacements. Rubber can go bad even sitting on a shelf in the dark in a warehouse. It ages/de-gasses from day one. Exposure to UV speeds up the process a lot though. When buying new rubber parts, start protecting it ASAP with conditioners because although new to you, it may have already sat on a shelf somewhere for years. So I would still be cautious of stockpiling rubber parts.
Personally I have had good luck restoring rubber parts using wintergreen oil with great results. I've never done any weather stripping, but for carb boots, air intakes, etc. Wintergreen oil is the only thing I have ever found that actually works.
Everything I have received from them is as new so hopefully you’ll be fine.Good point. I'm sure these parts are old and have been sitting in the michigan warehouse for years. I'll see how they look and decide if I want to use them or not. The ones on I have are almost flat so there's no restoring them.
They very well could be a decade old, but since they have been stored out of the elements they should be in better condition then what you have currently, just don't expect showroom new condition.Good point. I'm sure these parts are old and have been sitting in the michigan warehouse for years. I'll see how they look and decide if I want to use them or not. The ones on I have are almost flat so there's no restoring them.
Would it be possible to print new rubberlike parts out of TPA plastic after some trial and error?Personally I have had good luck restoring rubber parts using wintergreen oil with great results. I've never done any weather stripping, but for carb boots, air intakes, etc. Wintergreen oil is the only thing I have ever found that actually works.
I've only dabbled in 3D printing, but I imagine as the technology is improving it would be possible, but is TPA malleable enough to be used in a weather stripping scenario? I could see a small intake hoses or something like that, but weather stripping needs to be thin and able to be fully compressed and then return to it's original shape like memory foam.Would it be possible to print new rubberlike parts out of TPA plastic after some trial and error?
While nearly everything is "possible", weatherstrips are currently far from practicable. The shapes are complex, the parts are fairly large and, as @steveorama said, the materials are not the most suitable.Would it be possible to print new rubberlike parts out of TPA plastic after some trial and error?
I'm actually not quite sure about the specifics of TPA other than it's rubber like. I've never printed with the material. I'll need to look into it.I've only dabbled in 3D printing, but I imagine as the technology is improving it would be possible, but is TPA malleable enough to be used in a weather stripping scenario? I could see a small intake hoses or something like that, but weather stripping needs to be thin and able to be fully compressed and then return to it's original shape like memory foam.
Is that the one people always rip on as ugly?eBay has a original fly scatter with mounting hardware
Yes. There's form AND function.Is that the one people always rip on as ugly?
I’ve got one. I like it.Yes. There's form AND function.
In this case the flyswatter actually works
. . . . . . . even if many call it an ugly duckling.
You should look into adjusting the windows to get a good seal. The window is highlighted adjustable. The side deals can be found but installing them is a bitch. Take care of themas I suspected, im fubar
EDIT: partially fubar
Cover & Components for 2009 Saturn Sky | GMPartsDirect.com
www.gmpartsdirect.com
Rob makes a good point.You should look into adjusting the windows to get a good seal.
Oh there perfectly adjusted. They were doublechecked when I had the regulator/motors replaced. There are two seals that meet right in the middle of the window. That area is completely flat, and there is a minor leak whenever the top gets wet. The top is not leaking (thankfully), but drops in between the seams of the seals go inside the glass.You should look into adjusting the windows to get a good seal. The window is highlighted adjustable. The side deals can be found but installing them is a bitch. Take care of them
Regarding rubber protection, thought I'd share something that not only cleans, but really has improved the quality of my seals. Try Meguire's Marine/RV 57 Vinyl & Rubber cleaner protectant. I apply and re-apply 3x, letting it soak in. Incredible!Rubber parts are always an issue unless they are still manufacturing replacements. Rubber can go bad even sitting on a shelf in the dark in a warehouse. It ages/de-gasses from day one. Exposure to UV speeds up the process a lot though. When buying new rubber parts, start protecting it ASAP with conditioners because although new to you, it may have already sat on a shelf somewhere for years. So I would still be cautious of stockpiling rubber parts.
Ive had very good luck with my saab 9-3 convertible using shin-etsu silicone grease which is the oem acura/honda brand. Stuff is really good, not greasy at all and doesnt attract dirt. I expect to have it tomorrow and give all seals a thorough work with it over the weekendRegarding rubber protection, thought I'd share something that not only cleans, but really has improved the quality of my seals. Try Meguire's Marine/RV 57 Vinyl & Rubber cleaner protectant. I apply and re-apply 3x, letting it soak in. Incredible!
I was primarily referring to restoring as opposed to protecting. It's one thing to maintain rubber parts with conditioners etc continually over time. It's another thing to take a 20 year old piece of rubber that's never been treated a day in it's life and rub some conditioner on it. It simply doesn't work. The wintergreen oil with rubbing alcohol bath is to this day the only thing I have ever found that actually restores old hard rubber parts. It smells nice when you are done too as a bonus!Regarding rubber protection, thought I'd share something that not only cleans, but really has improved the quality of my seals. Try Meguire's Marine/RV 57 Vinyl & Rubber cleaner protectant. I apply and re-apply 3x, letting it soak in. Incredible!
Whats the mix ratio of oil to alcohol, and what proof do you use?I was primarily referring to restoring as opposed to protecting. It's one thing to maintain rubber parts with conditioners etc continually over time. It's another thing to take a 20 year old piece of rubber that's never been treated a day in it's life and rub some conditioner on it. It simply doesn't work. The wintergreen oil with rubbing alcohol bath is to this day the only thing I have ever found that actually restores old hard rubber parts. It smells nice when you are done too as a bonus!
