41 - 49 of 49 Posts
lolol.
wow the difference is stark. but i couldnt really tell from that picture other than the shape is different. might have to see about getting myself a set.
Good luck. As @Robert Neighbours stated there are very, very, few sets known to exist. A group of one side showed up a few years ago, but overall they are truly unicorns.
There have been a couple of comments about making reproductions, but no one has succeeded. Yet.
Not sure if it’d be considered a ‘mod‘, but a convenient adjustment I made was to remove the packed-in grease from the push-type handle of the waterfalls center storage bin.
You know when you press that knob in to expand it... how it takes 32 years to slowly depress? Well, if you unscrew the door, then unclip the handle, you could clean up the grease and have a quick action button that springs out instantly as you press. Since I use that storage bin often, this was a game-changer for me.
Other mods that I’ve enjoyed-
* Expanded rear trunk (though you must use a different exhaust setup to get the most out of the space).
* Add aftermarket seatbelt holders which allow the seatbelts to not slide back behind the seats.
* Modify the front wheel wells where the upper 1/3 section sits on the hood. This allows for a more enjoyable, easier accessible engine bay. A fellow kappa member has done it and it looks fantastic!
* Front big brake Brembo brake swap- using the Cobalts Brembos, installing larger calipers and rotors (will need to machine the rotors to fit the kappa hub and will most likely need larger rims - like 8.5” rather than the stock 8‘s- for this swap to work). There are co‘s that sell these, or similar kits, such as Wilwood.
* Ceramic coat the turbine housing of the turbo, the CHRA, exhaust manifold and down-pipe.
* And lastly, one I’d like to tackle at some point- create a trailer from the back half of a kappa.
Hello !!!!! I will list a few of the mods I have made to my Sky:
Led trip (It looks as cool as the photo). I love it.
Throttle Controller
Led sides
Garage botton
Trunk air scape
This is not a mod. I fixed the bumper with fiber glass sheets.
And the Side fender as well !!!!!
Throttle Controller
Led sides
Garage botton
Trunk air scape
View attachment 127553 View attachment 127554
View attachment 127555 View attachment 127556 View attachment 127557
Love that light under the wing. Care to share how it was done? (Though I have ideas)
RPM-motorsports.com tune is just under 400 for a custom tuned to your car via cable hooked to a little laptop they send you. Once the virtual appt is set, give yourself two hours to get the tune compete. It’s wonderful! Martin makes sure EVERYTHING is PERFECT before he lets you go. Then you send the laptop to next person that is waiting for a tune.
trifecta budget tune caused some check engine lights and power cuts on my previous Sky. So, I unistalled the trifecta tune and had RPM do it properly for me. So worth it. Car runs so well.
check the forums for tune threads: there’s a lot to read up on and there are good experiences and bad experiences.
Can't speak for the other tunes but can speak for the RPM-Motorsports tune. I was fortunate to get my tune while I was attending NASSAM2024. Martin was in the passenger seat datalogging and tweaking the tune. He stated that I picked up 60 WHP. Its not the same car, it went from being an animal to being a beast.
Sure. I have a video in my channel. Even when it is in Spanish it is easy to follow. Now....in regards of the stip..... I just erased the link from my video because now a days the seller doesn't have the red one anymore.
Here is the video:
41 - 49 of 49 Posts
